E emrahtufan New Member May 29, 2020 #1 We can't get the same detail when we use 4-bolt joint detail on steel beam and reinforced concrete column/beam connection detail. Sent via iPhone using Tapatalk
N nurgulkaya New Member May 29, 2020 #2 Re: Steel beam - reinforced concrete column/ beam connection detail Hello; The problem is programmatic. There was a problem because the connections were written for steel - steel in the first place. For now, you need to edit the drawings. Good work.
