STATUS OF BEAMERS ON DIFFERENT LEVEL ON THE SAME FLOOR
tabanlioglu
When we enter beams on top of each other at different levels on the same floor, a full-length drawing is made in the vertical expansion of the beams and the beams in between are not taken into account. A similar situation is experienced in the connection of beams between columns. On the same floor, different inclined beam drawing vertical expansions and inclined beam beam expansions can be drawn under the upper beam. not reflected.
We are working to include the requests and corrections for the drawings in 6 versions in the upcoming updates. Column application, beam and panel expansions will be completely renewed and put into use.
Version 6051 has been released, but no changes have been made to the issues we mentioned7. When will the changes you mentioned7 be made? I would be glad if you provide information.
The new column application plan and vertical expansion will be in the next update (6.0100).
