Re: SG Pursantaj SGPursantaj: It is the ratio of the reinforcement amount calculated from the design influences to the column area as a percentage. A negative value indicates that the cross-section meets the effects with the concrete area without even needing reinforcement, or if it is positive and below the minimum pursantage, the column cross-section is not forced.
