Reform Group
Hello, I can't see any results about stapling in the reports of the hollow floor project I have done. The page is completely blank. How can I solve this problem? Best regards, good work.
I am attaching a project example. Best regards, good work."cakilomer":1dsgllzu" said:Adding the project will be helpful. The punching part may not be marked in the reports section, or if you add the project, the friends who help can help more efficiently
I don't have a problem with foundations, I want to see the results of stapling on the flooring."cakilomer":23196kdk" said:Punch control is not performed on continuous foundations.
Hello, Stapling control is made on beamless slabs and beamless rafts. Shear strength control and stirrup calculations are made in beam systems. Good work"Reform Group":1asbz3ns" said:I have no problem with foundations, I want to see the results of stapling on the flooring."cakilomer":1asbz3ns" said:Staple control is not performed on continuous foundations.
In beamed flooring systems The punching strength is not checked because the plates are supported on beams, not columns. There is no stapling circumference in the plates. Stapling strength is checked in beamless floors."Reform Group":26kg96ic" said:I don't have a problem with foundations, I want to see the results of staples on flooring."cakilomer":26kg96ic" said:Punch control is not performed on continuous foundations.
