Stapling problem in the column
mkrts88
When I define the P04 curtain as a column, a stapling problem occurs. If I define it as a curtain, there is no problem. Of course, 1/7 ratio is not provided. Although I do not model the curtain as a shell, there is no problem, I need to define it as a column, but how can I overcome the problem?
Re: Staple problem in column
"mkrts88":3jwxhov6" said:
When I define P04 as a column, there is a staple problem. It does not appear, I need to define it as a column, but how can I overcome the problem?
Stapling control is not performed on the curtains in the program, it is on our work list.
Re: Column stapling problem
"mkrts88":u430ci1t" said:
Can you add the project where you have stapling problem when you define a column?
I have added
Hello, stapling problem in S52 column D03 It is caused by the floor slab. You can arrange the slab edge of the D03 slab so that it does not overlap the column as in the example. Note: The elevation of the D03 slab was not compatible with the P03 curtain to which it was connected, it was made compatible. option checked. P04 modeled as shell. Good work
