Stapling error
serhat aydemir
it constantly gives me a punching error, I couldn't solve it no matter what I did, I increase the thickness of the foundation, I expand the foundation, it still does not work, I put the project, I would be happy if you look
Hello, I am constantly encountering the stapling problem. I draw a 2m/2m box with the base edge of the raft under the punched column and I make it 20-30-40 cm deeper than the raft, and there is no problem. Of course, it will be a bit of a hassle when applied on site.
Although it seems appropriate in practice, the process you did did not seem right to me in terms of analysis.
"yunussacikk":1flcqox6" said:
hello, I am constantly facing the stapling problem. I draw a 2m/2m box with the base edge of the raft under the punched column and I make it 20-30-40 cm deeper than the raft and there is no problem.
I don't think they will do it in place unless you specify it as a special detail. It acts like a singular foundation in the raft, but I was wondering how you arrange it in the plan.
