stapling control
hkderinoz
Member
Good afternoon, while using idestatic version 6, there was a situation where we needed to define a virtual (h=0) column header for the column - raft junctions so that the program could perform the punching controls of the columns on the raft foundations. Do we need to make such an application in idestatic version 7 again? thanks
Hello, The situation you mentioned existed in version 5. In versions 6 and 7, punching controls are performed automatically on a beamless raft basis. Good work
What is the technical reason for not doing the punch control for panel objects? do you have friends who do stapling control? Are you doing hand calculations?
