The table height is calculated according to the value given in the raft settings to the program. If the value is left zero, it is calculated as Table Reinforcement Height = Foundation Height - 2*RateConcrete Cover Thickness. If you enter a value, the value you enter is added to the height of the tripod reinforcement. A negative or positive value can be entered. If you enter a positive value, you will increase the height of the coffee table reinforcement, and if you enter a negative value, you will decrease it. Calculated as Table Reinforcement Height = Foundation Height - 2*Rat Concrete Cover Thickness + InputDIIf. The thickness of the raft concrete cover is given in the raft parameters.
