The reason why I ask the following questions, especially after clicking the analysis icon, the program says to check the geometry, but when we press the geometry check button, it says there is no error, and it shows the ladder with a red arrow in the analysis display options. And I understand that I am doing something wrong when creating the ladder and/or selecting the options related to the ladder. I would appreciate it if you could answer these questions in an explanatory way. 1-When placing the ladder in the building, should the dimensions of the stairs and the space left geometrically be the same? 2-Does it affect anything if the size of the stairs is larger or smaller than the area where it will be placed? 3- When I click on the ladder icon, is there any difference in which point I place the ladder by holding it? (Is it a priority to place it on the vertical element?) 4-Is this what I need to understand from stair bracing: If the stair reinforcement continues inside the relevant element (beam, slab, foundation, curtain, column) there is support. and I can say that this supported edge of the ladder (the edge whose reinforcement enters into the element with which it contacts) is prevented from being translated and rotated. However, if the edge of the ladder does not continue inside the relevant element (beam, floor, foundation, curtain, column) with which it contacts, I can say that translation and rotation are not prevented. If what I'm talking about is true: Detecting edges for the structure-independent solution is simpler. 5-But if I want to solve it with the solution option together with Yapı; For example, if I mark the stair support edge connected to the Beams, does the term Connected mean Rotation and translation is prevented? 6-Does it also mean that the fixed support option is prevented from turning and shifting, and when is it appropriate to mark it? It is defined as "Staying distance: Give the amount of distance that will be valid for connecting the stair edge to the support". 7-What does the support distance mean more clearly, 8-In which situations do I need to change it?
