In case the stair supports are related to the flooring, if the support conditions are arranged according to the solution conditions together with the structure, analysis should be made according to the semi-rigid diaphragm option. In case of analysis according to the fully rigid diaphragm option, the stair support conditions should be arranged according to the solution situation independent of the structure.Note: These questions you asked in the e-mail you sent to our technical service on 24.10.2014 were answered on the same date. Good work."cakilomer":27lq5di8" said:How can we model the staircase and apply the fully rigid solution option so that its loads are transferred?
You are welcome. You can also contact by phone when there is something unclear in the mail. Good work"cakilomer":237xydop" said:thank you, Mr. Levent, I'm sorry for disturbing you in order not to make mistakes as there are some unclear points. GOOD WORK
