STAIR ANALYSIS
Hello. Can we analyze the example I added regarding the stair analysis, "By defining the calculation axles and defining the support conditions for the solution together with the structure"... Why did I add this example: I could not define the calculation axis "in the direction of the steps" for the type of stairs drawn on the ground and 1st floor..
The calculation axes of the ladder in the example you added can be defined and solved together with the structure. I rebuilt your ladder. Calculation axes can be drawn.
"Levent Özpak":3lrraxtd" said:
The calculation axes of the ladder in the example you added can be defined and solved together with the structure. I created your ladder again. Account axes can be drawn. I was able to identify the axles...
