In order to perform direct analysis from P-delta, analysis must be done with the general analysis method. The program cannot do this for the moment. For the analysis with the buckling length, the B2 coefficient should be calculated and should be less than 1.5. The user has to calculate the coefficient and verify that it is less than 1.50. For the approximate second order analysis, the coefficients B1 and B2 must already be calculated. The user needs to calculate the coefficient and enter it into the program. This is what I understood from your answer. Therefore, if the program analyzes with the buckling length, it makes more sense to first set the default value of 1.5, which is the upper limit, with the understanding of safety. In summary, in stability design, as in every program and design, the control and calculation of the engineer has priority.
