"lozhan":18nupd00" said:Hi Latitude and Longitude are the same but the results are different.
"mhmmd":3muse4da" said:"lozhan":3muse4da" said:Hi Latitude and Longitude are the same but the results are different .
"Ismail Hakki Besler":3muse4da" said:The same values do not result. Afad and ideYAPI use different algorithms. However, the spectrum curve you created using these values and the earthquake results we calculated using this spectrum are very It makes little difference.You can use Afadin values online if you wish.The important thing here is to calculate the spectrum curve correctly in the coordinates and ground conditions of your building and to make the earthquake calculation correctly in that coordinate and ground conditions.
