Splitting the curtain with a column
koleksiyoncu
First of all, I just graduated and I want to learn something 1- I want to divide my 25-gauge curtains with a column and connect them with a beam. I don't want to connect the curtain directly with a beam, but when I put a 25-gauge column into a 25-gauge curtain, it gives a sizing error what can I do 2- I have a small-sized curtain, what kind of solution is there? I can
Re: DIVITING THE SCREEN WITH A COLUMN Hello
"collector":kn7ibmmy" said:
1- I want to divide my 25-gauge curtains with a column and connect them with a beam. I do not want to connect the curtain directly with a beam, but when I put a 25-gauge column into a 25-degree curtain, sizing error What can I do for this
According to TBDY2008, you cannot make the narrow side of the column less than 30 cm, make the narrow sides of the column 30 cm,
2- I have a small size curtain, how can I solve it[ /quote] This is the warning given in the geometry control, even if you don't fix it. Errors must be corrected. Unver ÖZCAN
Re: DIVITING THE SCREEN WITH A COLUMN But that column will not continue on the upper floors, I will only use it in the basement to connect the beam. I looked at the newly built projects, most people approved by the municipality and there was no problem. Even though the transverse reinforcement is not compacted and these columns are 25, is it possible to assign 25 columns inside the curtain another way?
Re: DIVITING THE SCREEN BY COLUMNS
Then remove the columns with 25 cm narrow sides Let the beams sit on the curtain.Watch the following videos from start to finish.
Ünver OZCAN
"collector":2hoe4sx8" said:
But that column will not continue on the upper floors, I will only use it in the basement to connect the beam, I looked at the newly built projects, most people approved by the municipality and there was no problem According to tbdy2018, what I have seen is that there is no curtain between two columns and no transverse reinforcement classification is made, and even though these columns are 25, is the assignment of 25 columns inside the curtain another way
Hello, the fact that most people have done it does not mean that it is correct. In order for the data entry to be correct, a column in the thickness of the wall must be defined at the head of the panel curtain, this is not the case in IdeStatik.If you still want to create a header area at the end of the curtain, you can do this by entering the properties of that curtain and specifying the left or right header size from the Reinforcement tab, so that the program will warn you in the geometry control. If you do this by drawing a colon, the program will give a warning. It is normal because the elements entered with the column command are designed like columns in accordance with the regulation. If you design it like the curtain head area, it is part of the curtain and can be made 25cm. Best regards. Sent via iPhone using Tapatalk
