Splitting the curtain with a beam
doruk2292
Hello, When I throw a pillow beam between two curtains as in the appendix, it divides the curtain by the beam width. Is this something that should happen? yOr does it affect the analysis negatively? Best Regards, Doruk Araplı Civil Engineer
You can tell if there is a problem in a data entry by looking at the 3D model. At the point you see in the screenshot, the beam is connected to the panels with rigid arms. The beam panel is split. However, you have the chance to define the beam from below so that it catches the node of the curtain.
