This issue will be clarified in the new earthquake regulation. It is likely that the regulation will require the inspection of rib and cassette systems with a semi-rigid diaphragm. After the regulation is issued, this situation will be handled together with other issues introduced or changed by the regulation. We are waiting for the new earthquake regulation to be published. When using cassette in ideCAD, there is no problem with load transmission between backhaul. Due to the nature of this System, it results in this way. Rib and cassette systems behave differently from conventional beam-column systems. If you want the system you mentioned to transfer the load to the perimeter beams in the most accurate way, you should not include the system in the model with flooring beams and cassette beams. For ribbed systems to work as you expect, the ribs must be in the short span direction and the upholstery must have an aspect ratio of around 2. If you throw the ribs in the long direction and expect that the long main beams will not be loaded, the system will not work the way you want. The ribs, which do not require transverse teeth as per the regulation and whose system is selected in the long direction, should also be resolved by including the flooring in the program. In the attached images, the ribs are thrown in the short direction in the system on the left, and they are placed in the long direction in the system on the right. When the results are examined, whether the rigid diaphragm or semi-rigid diaphragm is dissolved in the systems placed in the short direction, moments in the direction you expect have occurred. However, when we include the floors in the system where the ribs are placed in the long direction, the long beams become a serious load and a span of 4.138 tm is formed. Especially the solution of rib systems, where you place the ribs in the long direction and the flooring aspect ratio is not close to two, gives very wrong and wrong results in the solution with the rigid diaphragm method. The analysis made with the rigid diaphragm method, however, gives results close to the real solution in systems where the ribs are placed in the short direction. When solving with ideCAD, especially in rib and cassette systems, solve with the analysis option "semi-rigid diaphragm" that also includes floors. In the image below, the solution is made using the rigid diaphragm method. In the image below, the system floors, ribs and beam columns are modeled and solved as a whole, that is, a semi-rigid diaphragm solution is used.
