Spacing at beam intersections
201968
Hello. There are 3 dimensions of space in the junction of the beams K02-03 and K02-04 in the attached project and photo, how can I solve this?
Re: SPACE AT BEAM INTERCEPTIONS As can be seen in the final project, the same problem persists in other beams as well.
Re: SPACE IN BEAM INTERCEPTIONS There is no problem in your curtain beam connections. The beams are attached to the curtain. Gaps in the perspective window are a situation that occurs in the image. It doesn't matter to the system. It's about display.
Thank you for your answer, Mr. Levent, I had one more question. As seen in the attached picture, the K05 beam does not continue along the P05 curtain. Normally, K05 AND K01 beams do not have to intersect?
"201968":xwsmfu5r" said:
Thank you for your answer, Mr. Levent, I had one more question, as you can see in the attached picture, the beam K05 does not continue along the curtain P05. Normally, the beams K05 AND K01 do not have to intersect?
Hello, The curtain is in the rigid direction. Beam reinforcements connected to the wall are extended to meet the conditions specified in TBDY 2018 Figure 7.7. It is a visual situation in the formwork plan. You can make necessary arrangements by using 2D drawing tools. Good work
