In space cage systems, I solved a system like the attached. However, I would like to get information about how to make connections to reinforced concrete and steel columns. Thank you Best regards...
Hello there; Space Lattice systems have special combinations. A connection is made with rods inside a spherical element. The image in the link will be helpful. The connection to the supports is produced in a similar way. These two combinations are not available in the program. You need to edit your drawings.
Hello there; We take your request for the addition of the Space Frame system combination as a note. It will be evaluated for R&D studies, but I cannot give information about the duration. Good work.
