Some tiles are not calculated
Hi, delete the K84 Beam stuck in the K14 beam from the side of the S12 Column and redraw the beam so that the nodal point remains inside the S12 column. In the corrected project in the appendix, the columns in the size of the curtain are modeled as panels. Good work.
Thank you Mr. Yasin. I had discarded the d248 and d249 tiles that you had thrown, but it was not able to calculate them. What's wrong with this flooring? Because my main project is 11 floors, I couldn't upload it here (because it's big). I want to fix it on it. I wonder if the problem is with the columns that are the size of the curtain?
"Salih Eser":3n1hp5bb" said:
Thanks Mr. Yasin. I had thrown the d248 and d249 tiles you had thrown, but he couldn't calculate them. What was the problem with this tile. Because my main project is 11 floors, I couldn't upload it here (because it's big) I want to fix it on that. I wonder if the problem is with the columns with the wall size?
Hello. You only need to delete the K84 Beam and redefine it in your project. It is not necessary to model the columns as curtains. In the attached picture there is the beam situation that you defined and I corrected. K14 beam and S12 The small piece of flooring between the tiles creates problems for all floors.
