* Beam, column etc. When we double-click an object in the reinforced concrete dialog menu, it finds the object. In the meantime, if the mouse middle button zoom command works, we can easily understand where the small-sized object is in the project. * When we say copy only active operating mode objects in floor copy, if we say delete old objects, architectural objects are also deleted. If we say deletion, old and new static objects are mixed with each other. What formula can be found for this? (Would it be too confusing if there was a tick like keep the columns, keep the walls, let the beams stay, let the windows stay?) * Add the layer name to the information that appears when we hover over an object. Although the length of the panel object is given, the length of the beam object is not given.
                     German
 German  French
 French  Spanish
 Spanish  Portuguese
 Portuguese  Italian
 Italian  Arabic
 Arabic  Russian
 Russian  Japanese
 Japanese  Turkish
 Turkish
