SOME BEAMERS GIVE ZERO REINFORCEMENT
adrian
FRIENDS, I NEED YOUR SOME URGENT HELP. I HAVE A PROJECT I NEED TO PRESENT, BUT SOME VALUES ARE PROBLEM, I GIVE IT IN ANNEXE, I'M GOOD IF YOU ARE INTERESTED
I didn't see any beams with zero reinforcement in your project... Short object warning in geometry control, you also have beams that exceed the maximum pursantage value. (Your project was made in demo. I looked at both 6.54 and 7 demos) In such cases, if you write your problem more clearly, you can get more accurate help. Example: I'm using this version, on that floor, on that beam, it looks like...
Thank you for your interest, Mr. Hakan. How can you decrease the increasing purchase rates? I have to make the presentation tomorrow, I would appreciate it if you would review my project in general and inform me about my shortcomings or for a better design.
By the way, in the short object warning, I created a 5 cm front movement in the drilling, so it gives a short object warning.
"adrian":362zqvdp" said:
Thanks for your interest, Mr. Hakan, how can the increasing rate of interest decrease. I have to make the presentation tomorrow. I would appreciate it if you could review my project in general and inform me about my deficiencies or for a better design.
The column system seems insufficient. Especially the columns in the middle region collect the earthquake effects in the x direction. Since the moment is high in the columns, there are naturally problems with the short beam and other beams that are continuous with the short beam connected to them. Try to spread the moment distribution to the project by increasing the number of columns in the x direction if possible.
