Solve two buildings on a single basis with the Get Basic Effects command.
ebasakin
Friends, for some reason, I am constantly having problems with the attached projects. I'm trying to solve two buildings on a single basis with the command get basic effects. But I am running into problem. The projects are attached. First I did the analysis, no problem, then I had the analysis done again, it gave a nodal point error. When the foundations dissolve the buildings separately, the foundation does not save. When they build a single foundation, it first saved and then failed.
Re: The problem that I could not solve Hello, In case of using the Get Basic Effects command, a solution without superstructure interaction is required. If you turn off this option in your combined fundamental model, there is no problem if you analyze it. You are getting the node error because of the stairs on the 1st basement floor. Make the support condition of the stair edge fixed support in the foundation connecting part. Double click the ladder -> Ladder Edit -> Static -> Make the finite apple width 5 cm. Your model will be analyzed in this way. As a result of the analysis, you will face the problem of soil safety stress. You are checking the ground safety tension according to the average tension. When you do it according to the maximum tension, the safety tension is still insufficient. I suggest you review your loads.
