There is no problem with this system! Everything is as planned..! RESULTS. I downloaded the project, all I did was delete the rafter raft system and model a beamless raft system, so it's not 120 cm, which is reasonable, so 70 cm. I only grew 1 meter from the outer axles, the superstructure is ok, it did not provide shear safety in 9 columns in the whole building This is achieved by enlarging the column size of 5 by 10 cm There is no problem with the beams. It works fine in the system, the 1st natural vibration period is 0.58 sec in the solution without pavement interaction, 0.62 sec in the solution with pavement interaction. There is basically no problem, a reasonable reinforcement was chosen for 70 cm thickness ( Q14/11- Q16/16, Q14/ 12-Q16/16) There is no problem in terms of ground safety tension, in all meshes I have looked at, the tension is under safety. AS A RESULT, THIS SYSTEM IS WORKING BEAUTIFULLY (CLICK WITH ANOTHER EXPRESSION) ..! It is evening, I have to take the order given by the lady and go home, if desired, I will add the solved project tomorrow. Good evening everyone, good work, good and halal earnings, I wish you all the best... G. KÖSE
