Solution without earthquake loading
izmirlimuhendis
How can I solve the construction without earthquake loading only under fixed and live loads. I said I should take the building importance coefficient to 0, the program was locked. The program does not allow me to get the coefficient A0 as 0. If I take a very small value, the stresses in the raft foundation are the same as 0.40. I removed the earthquake loadings from the combinations, but again, the raft reports write the earthquake loadings. Use seismic loads in soil safety control for foundations is unchecked, but it still uses seismic loads. version 8.503, by the way, I set the defined A0 value to 0.01 and nothing changes in the earthquake raft stresses.
"izmirlimuhendis":1h3ajsig" said:
how can I solve my construction without earthquake loading only under fixed and live loads. I thought I should get the building importance factor 0. The program got locked. It turns out the same. I removed the earthquake loads from the combinations, but it still writes earthquake loads in the raft reports. The option to use earthquake loads in soil safety control on foundations is not selected, but it still uses earthquake loads. By the way, I set the defined A0 value to 0.01 and nothing changes in the earthquake raft stresses
] Hello, -There is no possibility to analyze without taking into account the earthquake loads. Even if the earthquake load is zero due to the 0.9G+/-E (earthquake) loadings specified in Ts 500, it is taken into account in the design. In order to get the earthquake forces zero, Fx and Fy in the Analysis Floor Parameters dialog You can enter zeros in the columns and analyze. The program does not break when the Building importance factor is entered as zero in your project. (However, if the building importance factor is entered as zero in the program, the earthquake forces are still calculated according to 1.) In the project you have added, the foundation system is raft without beams. In order to perform the stress control only for vertical loads, select the option "Use earthquake loads in the ground stress control of non-beamed rafts". You need to uncheck it. Good work
