S1-In Semi-Rigid Analysis, when we make a solution together with the Staircase Structure, how can we see as a visual and report that the Load Transfer from the Stairs to the carrier elements it is connected to? (How can I see it on the beam, floor, column, curtain to which the ladder is attached?) When we determine the support conditions of the ladder, we actually determine its connection with that element. When I solve the s2-Ladder independent of the structure: Since the reinforcement of a staircase that prevents rotation and translation enters the element to which it is connected, should my user make these drawings (the reinforcement drawing that must continue in the element to which it is connected) in the staircase drawings? s3- Since I need to mark "Connected to Beams/Connected to Columns/Connected to Panels/Connected to Floors/Connected to Foundations/FIXED BEARING" when I solve the ladder as semi-rigid with the structure, should the user draw the reinforcement continuity with these elements to which it is attached? s4- When we solve semi-rigid with the building, does it include the stairs in the analysis and the reinforced concrete calculation just as it includes the floors and calculate? s5-Does it add step concretes (not coatings) to the concrete weight to the fixed load of the stairs? s6-Can I create and dissolve the stairs as slab flooring in the program?
