Hello, -P01-P02-P03-P04-P05-P06-P07-P08 curtains are entered as column objects. And the continuous foundation parts are defined to be under these elements. Column entities are bar elements. Continuous basic data entry should be made from one column to another column. Other findings and suggestions; -The foundations defined under the basement perimeter walls should be in the same direction as the panel (BP5-BP6-BP7-BP8) -P05-06-07-08 two columns were inserted in the attic above the curtain columns. In this way, a vertical continuity problem occurs in a data entry. (You can define two panel objects in the attic if you enter the relevant curtains as panel objects at the bottom and model them as shells.) - It is recommended to select "superstructure interactive solution" option in the analysis settings.
