It is quite natural that the reinforcement requirement in the basement and lower floors in some cases is less than the upper floors and If you add this projection, your friends will explain the reason to you."memox85":a5v7jmsd" said:if the upper floor reinforcements minimum option is not active in the columns, the basement reinforcements are less than the upper cards, interestingly
