Soil Safety Stress Increase Ratio
huseyinakkus56
Hello.. I wrote to the forum before, but it was deleted. We were able to increase the ground safety stress up to 50% (A, B, C Groups).
"huseyinakkus56":7sqoxak1" said:
Hi.. I wrote to the forum before but it was deleted. We were able to increase the ground safety tension up to 50% (A,B,C Groups) Is this option removed or did I not find it in the program?
By the way, Mr. İsmail, can you take a look at this image? Although there is no soil safety stress increase, the report states that a 50% increase has been made. Also, it says Ground Class Z4, maybe you can make a change to ZD with the update.
Even if that section is marked, no increase is made in the account section if 2018 is selected. The matter you have stated is within our knowledge and in our notes. If you want it not to appear here, you can remove this mark from the 2007 regulation section and select the 2018 regulation again.
"Ismail Hakki Besler":g8o4ddy3" said:
Even if that part is ticked, no increase is made in the account section if 2018 is selected. The point you mentioned is within our knowledge and is among our notes. You choose the 2018 regulation.
Well, thank you.
