Snow load and carrier system coefficient selection
mehmetba
There are coating load and snow load parts in the static part of the coatings on the roofs, the coating load is known, does the program define a load when the snow load part is left blank? If so, what is it? Secondly, what should the carrier system coefficient be in a single column and console type parking lot project? According to what?
Hello there; If no value is entered in the snow load section, the program takes 0. The program cannot assign a load for any load that you do not enter a value for. As you know, if a coating is defined; In accordance with TS 498, wind loads are effected on the pavement. You can get these controls from reports. For example, if you get a steel purlin report for the coating load, you can examine the loads in detail. You should choose the carrier importance factor in accordance with TDY 2007. Good work.
