Small opening between column and curtain
yunussacikk
hello, there is a small gap between the column and the curtain in my project. How do you think if I enlarge the columns and give them offset? Should I extend the columns all the way to the end of the curtain or would a small joint be sufficient?
Hello. My suggestion: --the elevation of the columns looks -90. There is a bracing error, set the elevation to zero --Correct errors in geometry control, --The rib beams should center the columns and walls, --the rib beams from the column or wall should not protrude more than d/2=15 cm, --check the loads, --this In this case, it is ok if the short beams save or the reinforcements are reasonable. --if it doesn't, you may need to install short beams (as far as the architecture allows) or additional seismic shears. Unver ÖZCAN
