Slowness problem in double vault design
erimer
Greetings, there is no speed problem in Idecad program in general, but even in a simple double vault design, even clicking on the smallest element and changing its properties takes minutes. Is there any solution to this? (file link below) Greetings and regards
Hello there; You are experiencing a slowness problem as your truss geometry has a curvilinear form in the lower and upper heads, all of your sections are pipe profiles, and the in-truss joint is welded. Necessary notes were taken for optimization. However, in the current version, unfortunately, there is no solution for this project. If you have another computer with high performance, if you continue with it, your time may decrease to less than 1 minute. Good work.
