Possibly, inclined column and curtain can be defined, column and the connection of the curtain with the beams can be provided."insmuh_gk":1bvs4o5t" said:Yasin, since the columns can be inclined, is there an alternative solution if a column is entered in the inclined part in the form of a panel header and the back part continues as a panel?
Hello. There is no possibility to define a panel with variable section in the program."batuhann28522":2q4xbzfv" said:good day.Is it possible to draw a trapezoidal Screen with one side 22 cm and the other 25 cm wide? I need such a screen due to architecture.
