Hello, The account axis of the two tiles that you get the tile thickness control error is defined as console. Click "Edit Slab Calculation axis" command, click axis number 1 in the plan and set the reinforcement type seen as Cantilever reinforcement to "Flat+pillar". Before analyzing, check the rigid floor selection in the Floor general settings. According to your project, the ground floor should not be defined as a rigid floor.
