Thank you for your answer, but I want tiles to appear when I'm in the analysis, that is, red and green. It is visible to another friend, but not to me bro."YasinTezel":cv66i2t0" said:Your question has been answered in this linkYou do not have permission to view link Log in or register now.
Thank you very much, brother"YasinTezel":ukhaahoi" said:Because the "Full Rigid Diaphragm" method was selected as the analysis method, you cannot see the floors in the Reinforced Concrete design "All deficiencies" review screen Semi-Rigid Diaphragm model If a solution is made with the tile, it will be displayed on the tiles. If you analyze with this option, the analysis results will change. It is not a mistake that you cannot see it in your project right now. You can continue in this way.
"YasinTezel":250qumjm" said:Because the "Full Rigid Diaphragm" method was selected as the analysis method, you cannot see the floors in the Reinforced Concrete design "All deficiencies" review screen Semi-Rigid Diaphragm model If a solution is made with this option, it will be displayed on the tiles. If you analyze with this option, the analysis results will change. It is not a mistake that you can't see it in your project right now. You can continue in this way. What should I do? 2 floors are not visible on the upper floor either
"YasinTezel":39c37zrm" said:Add the final version of your project
Did you take a look, bro?"YasinTezel":3kg4avfn" said:Add the final version of your project
