memorandum
Hello, We have 4 options in this section. Trapezoidal Sheet Composite, Composite Solid, Concrete Flooring, Metal Flooring 1-Concrete Flooring option has Floor Thickness in the Geometry Section. Let's say this is 10 cm and 250 and 350 are added to the coating and live load sections in the loads section. When we enter the values, does it add 10 cm concrete for the slab thickness. That is, if we say 250 in the loads section and 250 kg from the slab thickness, does the fixed load become 500 automatically. How does it take the value in the slab thickness tab into account? 2-For trapezoidal sheet; Trapezoidal sheet on steel, wicker steel and concrete are placed on it. There is no slip wedge, etc. Which type of flooring should be used? Can it be composite without throwing a slip wedge or is it a concrete floor? Good work.
