+1 After all, we don't weigh gold."insmuh_gk":2z24vn89" said:Sn colleague, Slab edge splits the beam in order to transfer the load from the point where it is attached to the beam as per the principle of the analysis engine. In your model, the split piece is so small that it cannot even be called a beam piece. It doesn't mean to create an exact copy-paste model. What will happen if you connect the relevant floor edge to the very corner of the beam? That image that upsets you will also disappear! After analysis, correct that tiny balcony piece with your hand on the mold plan. Best regards. G.KÖSE
+1Sn colleague, The slab edge divides the beam in order to transfer the load from the point where it is attached to the beam as per the principle of the analysis engine. In your model, the split piece is so small that it cannot even be called a beam piece. In this respect, engineering does not mean creating a model by copy-pasting the architect's design exactly. What happens if you connect the corresponding slab edge to the exact corner of the beam? That image that upset you will also disappear! After analyzing that tiny balcony piece, correct it manually in the mold plan. Greetings and regards. G.KÖSE
