Single storey building with only basement
Emre.Ozcan
Hello, I have a project in which I will draw the boiler room consisting of only the basement floor. Since I cannot delete the ground floor, I cannot design a boiler room with only a basement floor. When the ground floor is defined at the basement floor levels, dynamic analysis cannot be performed because it is rigid in both directions. What kind of solution method should I apply? Thanks in advance.
Re: A 1-story building consisting of only a basement Hello, There is no need for a solution by accepting that floor as rigid in a building with only one floor. You can analyze without accepting the solid as rigid. Good work
The term "rigid basement" can be somewhat misleading as a word. The main idea is not that the basement should be rigid, but that it should be [/u][/b] rigid compared to the upper floors and show different dynamic behavior:
