Single foundation reinforcement problem
tevfikbayir
For now, I'm using idecad reinforced concrete 8 demo to find out. My question is, when I use a single foundation, the ground says safety is negative. When I look at the drawing details, a single row (X and Y) is laid on a single basis. I couldn't get it to put a top row. Is there?
Hello. I wonder if it's because I'm using a demo or is there another way?[/quote] There is no difference between the demo program and the main program. You can't print out in the demo, that's all. If the ground safety is negative, you need to enlarge the single foundation, Generally, no reinforcement is placed as the top row, The irons placed are called X and Y direction singular foundation reinforcements.The program does not use mesh reinforcement on individual basis (it is used in raft foundation and flooring.) Ünver ÖZCAN
Thank you very much, Mr. Unver, thank you very much for the answer, what I meant by the straw was to specify a single row. So, should I understand that the singular basis in the program always calculates this way? I usually worked in foreign projects, but, even if it is connected to a static calculation, even if it is a single row, it is a single row. I've never seen the basic shape equipped. Thanks again for the answer. Tevfik
"tevfikbayir":3eye4ovi" said:
Unver, thank you very much for the answer, I meant by straw to indicate a single row. I have never seen a single row reinforced foundation, even if it is connected, even if it is a singular foundation. Thanks again for the answer. Tevfik
Your question is not about calculation, it is about reinforcement. In single foundations, reinforcement is done according to the principles given in TS500. In single foundations, calculation,
Currently, I am using idecad reinforced concrete 8 demo to learn. My question says that when I use a single foundation, the ground safety is negative.
Overcoming the ground stress has nothing to do with the single foundation reinforcement scheme. . You need to increase the basic dimensions.
When I looked at the drawing details, there was a single row (X and Y) on the single base. I couldn't get it to put a top row. Is it because I'm using a demo or is there another way?
Alternatively You can also enter single foundations as raft slabs.You can define calculation axis in both directions in raft slab and you can select top flat - lower flat reinforcement in calculation axis properties.Define raft slab and raft slab in a closed area that you will draw with the slab edge in singular foundation size and thickness.
