Since the ground results are low, it gives ZG error on the raft
yousef
HELLO. AT THE ATTACHED FILE, THE GROUND RESULTS ARE LOW, RADIE MAINLY GIVES A ZGHATA. I WAITING FOR YOUR COMMENTS TO FOLLOW THE PROBLEM. RESPECTS
Re: You give ZG error on the raft because the ground results are low You haven't added the project.
Re: Since the ground results are low, ZG error is given on the raft it gives an error while loading the project. If there is any e-mail address, I will send it there. Thank you for your interest.
Re: Since the ground results are low, ZG error is given on the raft HELLO. I SENT THE PROJECT AGAIN TO YOUR EMAIL ADDRESS.
Re: Since the ground results are low, ZG error is given on the raft Hello I made a semi-rigid diaphragm, column, beam, slab, foundation, staircase arrangement in the project. I entered a ground safety enough to save the superstructure because the ground safety stress is very low. If the soil safety is really 9.5 t/m2, you should apply soil improvement or pile foundation. Unver ÖZCAN
Re: Since the ground results are low, ZG error is given on the radial HELLO LORD SERIOUS. THANK YOU SO MUCH FOR YOUR HELP BUT THE FLOOR VALUES ARE MAXIMUM 10 T/M2 BED COEFFICIENT IS 1000 FLOOR D. I TRIED TO SOLVE IT WITHOUT BORED PILE BUT IT IS SOME DIFFICULT AGAIN THANK YOU SO MUCH.
