serkankaradag44
good day, can I get information about the siege issue in the column-beam junction shear safety? besieged or not besieged what does it matter, should it be seen as a mistake.thanks
TDY related to this topic You can review the 2007 Article 3.5 and its continuation..."serkankaradag44":1u47r6i2" said:good day, can I get information about the siege issue in the column-beam junction shear safety? What does it change whether it is surrounded or not, should it be seen as a mistake.thanks
besieged/unsieged in capacity calculation There is a difference depending on the situation."serkankaradag44":2dzwqlwv" said:good day, can I get some information about siege in column-beam junction shear safety? What does it matter if it is surrounded or not surrounded, should it be seen as a mistake.thanks
