IT GIVES CUTTING SAFETY ERROR FOR SHORT BEAMERS FROM THE ELEVATOR CURTAINS, I TRIED TO CORRECT IT WITH THE STRAPPING DIAMETER AND RANGE, WITH LOADS, DIMENSIONS BUT IT IS NOT WORKING, CAN YOU PROVIDE A DIFFERENT SOLUTION, GOOD WORKS
If you don't have to throw those beams, try not to throw them, if you post a photo of the project, it may be more useful or if you can add the project, it was sent from my ALE-L21 using Tapatalk
Assign freedom to the ends of the short beams that come into the curtain. Select both M2-2 and M3-3. In this way, it will not take moment from the curtain, but that moment will be transferred to other elements. There will be an increase in iron in other elements.
