Reform Group
Hello friends, I have a problem. In the building, which is a shelter, the system is solved without any problems before the panels enter the system, but when the panel is involved, the system gives an error. When I place the panels, it first gives an intersection error. I solved the problem by lowering the panels by 1mm. Ornamental tiles exceed the deflection limit. Ground security becomes negative. You can find the full file in the link below. I would appreciate if you can help me if there is a mistake I made or something I can't see. Good work.
Log in or register now.
