In an existing architectural project, there are two strip band windows on one side of the shop floor. I have three column elements respectively affected by this band window. I have taken the lnet value of 0.5 m for my columns, which will exhibit short column behavior due to the rigidity of the wall. (band window height 50 cm) After the analysis, I left the lnet value to the "Find the Program" option as the amount of stirrups thrown out was not enough for me. My column height is 4 meters. As a result of the analysis I made again, I determined from the reports that the amount of stirrups thrown and the shear force value (''And''
coming to the column for both cases were the same. In such a case, short column behavior is observed, but I could not understand how to take precautions against this situation in our program. How can I prevent this behavior? Thank you ... Civil Eng. Hakan ARKAN
