Shear Force Ratio Monitoring in Columns and Walls
qwerty
Each Shear forces on columns and walls in value and ratio (the ratio of shear force carried by the element carrying the shear force on that floor): -How can I see it as a List in the program? -How can I see proportionally (the ratio of the shear force carried by the element carrying the relevant shear force on that floor) in the visualization part of the program? -How can I see it in the reports section?
Mr. Hakan, In the 1st picture you sent: the total shear force and ratio of the curtains on the floors. In the 2nd picture you sent: Again, the shear force and ratio of each of the curtains on the foundation. Can we see the shear force value and ratio of each Column and Screen As in the 2nd picture you sent within each floor? For example, on the foundation or on the 5th floor, the shear force value and ratio of each column (same as on the bulkheads)
"qwerty":1t8vcjh9" said:
Hakan, In the 1st picture you sent: the total shear force and ratio of the curtains on the floors. In the 2nd picture you sent: Again, the shear force and ratio of each of the curtains on the foundation. The shear force value of each Column and Screen and ratio as in the 2nd picture you sent in each floor?For example, on the foundation or on the 5th floor, the shear force value and ratio of each column (same as on the curtains)
hello, The purpose of the sample report I added is for the alphas control in the earthquake regulations.There is no listing program as you mentioned.
