Shear Error in Column
zekaikc
There is a level difference in our project and there is a cutting error in the column at the exact boundary where the difference is. Increasing the size doesn't help. Is there any solution?
"zekaikc":3r7en6j7" said:
There is a height difference in our project and there is a shear error in the column at the exact boundary where the difference is. Increasing the size does not help. Is there a solution? Column free length is detected as -0.45 m. You can change the column free height by ticking the "Defined" option in the Column free height (Ln) section from the Column Properties/Static Reinforced Concrete tab.
"Levent Özpak":1lpzgabu" said:
"zekaikc":1lpzgabu" said:
There is a level difference in our project and there is a truncation error in the column at the exact border where the difference is. Increasing the size doesn't help. Is there a solution?
Hello, due to the connection of curtains and beams at different levels in column S09, the free length of the column is -0.45 m. perceived as. You can change the column free height by selecting the "Defined" option in the Column free height (Ln) section from the Column Properties/Static Reinforced Concrete tab. Good work
Thank you for your reply. After your message, I started a detailed research on the short colon effect. I could not find an article on the internet about how the free column height should be entered into the program for the column I mentioned in our project. Is it possible for you to provide information on this? Good work.
"zekaikc":1gw1p8da" said:
Thank you for your reply. After your message, I started a detailed research about the short column effect. I couldn't find an article on the internet about how to enter the free column height in the program about the column I mentioned in our project. Could you give some information about this? Good work.
Hello, The free span of the beam between the column or wall faces can be taken as the free height of the column, and the distance between the lower level of the K56 beam and the upper level of the P9 curtain in the project.
