Hakan Bey also stated that whether you mark a shear wall as a sub-basement or not does not change the dynamic behavior of the structure. That is, the center of rigidity of the structure and the earthquake force to be calculated (independent of Ra) are the same. While calculating the earthquake load reduction coefficient Ra, the carrier We use the system behavior coefficient R. In the calculation of R, we first select the value suitable for the building system from the table and start the analysis. Then we make the alpha-s calculation and calculate the real value of R and therefore Ra. The approach of the regulation in the calculation of alpha-s is the total base shear force of the curtain shear forces Here; 1-) If there is a rigid basement floor, we are told to calculate the total shear force of the curtains on the floor right after the basement floor and to proportion it to the total shear force in that floor again. If the basement floor is closed with curtains on one side, it is considered as rigid, but one or more It is not said what to do if there are no curtains on many fronts. However, it is very clearly explained how to decide this
2-) We are told not to take into account the curtains that do not protrude throughout the building and do not act as the main curtain of the building, even if they are not in the rigid basement floor, while summing the shear forces. After you mark the floors you want to be a rigid basement in the ideCAD floor settings, if there is a curtain that you do not want to be included in the alpha-s calculation on a normal floor, we enter that curtain properties and mark it as "subbasement curtain". "Thanks to you, I learned that my opinion was wrong. In order for me to accept rigid direction in the program, as far as I understand from the relevant article (a) of the regulation, I need to surround it with curtains from 3 sides on both floors. is it correct ? respects
