She draws the curtain reinforcement like a basement curtain
br63
IDE IS LOOKING AT THE EARTHQUAKE CURTAIN IN THE LAST VERSION, EVEN IF I DRAWING THE EARTHQUAKE CURTAIN. I WOULD LOVE TO HELP YOU.
places; Actually, I don't have a project at hand, I drew it for trial purposes. When I say reinforced concrete, it solves the curtain without a cap. In the past, when we made it in the form of a column, it turned into an automatic curtain, but in this version it does not work that way anymore. For example, I drew something like a reinforced concrete design. If you say curtain reinforced concrete, there is only one distribution and vertical reinforcement. I will.
Hello, In our old versions, if the column is in screen size, it was automatically converted as you said. (ideCAD 7.022) With ideCAD 8, the user should enter the column with the column command, if the element is in the screen size, he should enter it with the screen command. In short, we enter the column with the column and the curtain with the curtain commands. The program does not convert automatically.
yes, but now I have encountered this problem even though I draw with the curtain command..it may be because it is a demo..but even though I draw with the curtain command, it solves it as a basement curtain..
If you do not meet the Hw/lw > 2 condition, no header region is created on the curtains. If otherwise, add your trial model and let's examine it.
