semi-rigid
Apocalpyse
Hello, when I try to solve the attached file semi-rigid, it closes. ide gives an error, can you check if there is a problem somewhere?
MY SUGGESTIONS from Mr. Apocalpyse, --It doesn't count if you solve the ladder this way. --Resolve the ladder by checking the option "Supporting conditions for solution with structure" and giving the support conditions. --It would be better if you put a mezzanine beam to support the staircase under the K15 beam.
