Hello, I have some questions, I would be very grateful if you could answer them urgently. 1-) Since there is only the ground floor workplace in the project, I solved the hollow block, which one would be more correct if the other floors were slab slab semi-rigid and fully rigid? When I solve semi-rigid, a1 irregularity is 1.52 and does not give B error. When I solve fully rigid, a1 irregularity is 1.33 and it gives B error in some columns. 2-) In one of the raft flooring additional reinforcements, the amount of reinforcement saves a lot of Q20/5? 3-) In some beams, there is a deflection of 10-17 mm, the deflection does not exceed the limit, but I want to ask if these values are too much in terms of application? If you have problems with data entry or have different solutions, I need all your comments and criticisms. I wish everyone a good work
