engineer_yildiz
Some sources have suggestions regarding the determination that the system works semi-rigidly. With this proposal, they generally refer to the ratios of the Diaphragm Floor displacement to the Diaphragmless Column (without floor = no diaphragm) displacement under the same horizontal force. My question is: a) How can I see the displacement of each column without diaphragm in İdecad? b) and how can I give these columns the shear forces in the diaphragm system? c) Where can I see the floor displacements only as displacements, except for Irregularities etc. d) Do you have any suggestions for semi-rigid fixation?
